Using DCFIFO from Quartus IP in Qsys with avalon mm at write side
Hi Athira,
Yes, you can do that using some logic in your custom component.
- Interface your DCFIFO and custom IP.
- Write a logic in custom IP to control DCFIFO read/write.
Refer below links design example and DCFIFO & avalon mm user guides.
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-ip.html
https://www.intel.cn/content/dam/altera-www/global/zh_CN/pdfs/literature/ug/ug_fifo.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
Anand
Hi Anand
I already did the steps you mentioned above. But I am not sure how to acheive the control of making avalon to wait until the FIFO is not full . What would be the procedure to do the same ?
- ASuba7 years ago
Hi Anand
I am doing the same. I am sending data continuosly using the Software in Linux.(HPS system). How can I qualify the wait while I send the data continuosly ?
- AnandRaj_S_Intel7 years ago
Okay,
- You can write to fifo if empty/rdempty/wrempty asserted and full//rdfull/wrfull is deassert.
- Read from fifo if empty/rdempty/wrempty deassert and full//rdfull/wrfull is asserted.
Which will make avalone bus wait.
Anand
- ASuba7 years ago
Hi
Yes I need to write in to DCFIFO when its not empty and need avalon to wait if the FIFO is full so that atleast once data is read out and its filled at same time.
I am not sure how to get this avalon wait signals from qsys.
>>Avalone is in wait state until you given write or read signal from custom component.
If fifo is full assert read signal & deassert write and when if fifo is empty assert write signal & deassert read.
