14 years agousing clock
Hi! I'm a beginner with my DE2-115 and vhdl programations. I'm trying to do a simple logic: make a led blink. To do this, I'm working with clock. But, I'm with some problems, because the led doe...
14 years agoHi.
I've tryed to do the modifications, but with no success! Now, an error:Error (10309): VHDL Interface Declaration error in TESTE_CLOCK.vhd(13): interface object "clkout" of mode out cannot be read. Change object mode to buffer. can you help me again!? the code: entity TESTE_CLOCK is port( clk:in bit; clkout:out bit); end TESTE_CLOCK; architecture behavior of TESTE_CLOCK is begin process(clk) variable cnt : integer range 0 to 25000000; begin if(clk'event and clk='1') then if(cnt=25000000)then cnt:=0; clkout<= NOT clkout; else cnt := cnt+1; end if; end if; end process; end behavior; tnx
