9 years agoUsing Byte Blaster Rev. C with FTDI232RL breakout board
I have a USB Byte Blaster Rev. C. For certain reasons I am trying to connect my FPGA to a breakout board that has a FTDI232RL on it. There are 3 USB cables that I have to use at this time. The ...
9 years agoHi XAUI,
This is kinda expected when using USB Blaster cable with another FTDI chip at the same time. Unless the driver provided for the external FTDI is different, then only Quartus programmer/Nios EDS can detect the FTDI chip separately. You may consider to use USB Blaster II cable as this cable is using a different driver (WinUSB drivers) from FTDI driver. Thus there won’t any confliction when using other FTDI periphery the same time. Regards, nyusof (This message was posted on behalf of Intel Corporation)
