Using array
If u r using
type is array (.. to ..) of std_logic_vector (.. downto ..)
How do u know its single ended, dual ported , .... ? Or is the best way to program with Insert templates or mega wiazrd ? It would alse be usefull if u can give me a good tutorial with tips and tricks for best- (reducing resources) and faster programming.6 Replies
Here is a question: How to place my 2-d array,which is signal,writable and readable, into a flash memory?
Board Info: Nios II Cy2 ep2c35 Thanks in advance. - Altera_Forum
Having two addresses means dual port.
So a write to one adress + a read from anothers adress is possible with single ended ?
Thx for your effort! - Altera_Forum
reading and writing to the same address usually isnt possible in the same cycle, or if it is, you have to use the ram asynchronously which Im not sure is possible with all devices. Using it asynchronously will reduce your FMAx.
If you are reading and writing, usually you read in 1 clock, and write back in the next (while simultaneously reading the next address). - Altera_Forum
i'm using the array as a followed:
In one cycle. If the input data is greater than the value in the array -> overwrite array. Compiler gives the warnig that aditional logic is being added because of the read and write action in one cycle. Is this single ended or dual ported. I'm confused because of the two actions, but to the same adress. - Altera_Forum
An array is just an array. How you access it affects whether the synthesisor implements a dual ported ram or not. If you follow the coding guidlines, then it will place a ram block for you. If you break these guidelines, it will implement it in logic (and eat your device up).
If the array that is accessed is a contant, it will place a rom, if the array is a signal or shared variable, it places a ram. If you do two reads and two writes to the array in a single clock cycle, its dual ported, else single ended.
