11 years agousing ALTUFM_PARALLEL on MAX V
Well, my first thread has crashed... --- Quote Start --- Hi, Since I have no response, I'll be simpler: 1) Is it possible to use the altufm_parallel (http://quartushelp.alte...
11 years agoHi,
I mean using the IP Catalog (which replaces the MegaWizard in Quartus 15) to create a new MegaFuction. There it gives you the option to set the port width. However, still only 9 address bits. You can probably also edit an existing MF from an older version, I did not try that. Btw, I realised that my suggestion with 10 address bits and a byte mux would not work... the UFM has no write mask. If you need ten address bits, you've got to write a FSM that does a read modify write (except if you do read only). Best regards, GooGooCluster
