16 years agousedw signal in scififo
Dear all, I used a scfifo, however the usedw seems not correct, it only had one bit, while the fifodepth is 32, fifo almost full value is 30, the definition of usedw is "Show the number of w...
16 years agoOf course FIFO usedw "has" more than one bit. I guess, you didn't tell the real problem. If you are actually trying to access usedw in Signaltap II or Quartus simulator, you apparently searched the node in the wrong place. It has to be accessed at it's source, in the FIFO compenent directly.
