16 years agousedw signal in scififo
Dear all,
I used a scfifo, however the usedw seems not correct, it only had one bit, while the fifodepth is 32, fifo almost full value is 30, the definition of usedw is "Show the number of words stored in the FIFO". why is that, and how to use it? anyone can help me? thank you very much!3 Replies
I used Modelsim to do the simulation, and see all the signals in the fifo, and only see one bit of usedw:), even I define the wire connected to usedw to be 5 bits
Is there anything wrong? I attached figure of modelsim simulation the selected codes are: ... parameter DATAWIDTH = 32; parameter MAXBURSTCOUNT = 4; parameter BURSTCOUNTWIDTH = 3; parameter BYTEENABLEWIDTH = 4; parameter ADDRESSWIDTH = 32; parameter FIFODEPTH = 32; // must be at least twice MAXBURSTCOUNT in order to be efficient parameter FIFODEPTH_LOG2 = 5; parameter FIFOUSEMEMORY = 1; // set to 0 to use LEs instead ... input user_write_buffer; input [DATAWIDTH-1:0] user_buffer_data; wire [FIFODEPTH_LOG2-1:0] fifo_used; ... output wire [DATAWIDTH-1:0] master_writedata; ... wire read_fifo; ... ... ... // write data feed by user logic scfifo the_user_to_master_fifo ( .aclr (reset), .usedw (fifo_used), .clock (clk), .data (user_buffer_data), .almost_full (user_buffer_full), .q (master_writedata), .rdreq (read_fifo), .wrreq (user_write_buffer) ); defparam the_user_to_master_fifo.lpm_width = DATAWIDTH; defparam the_user_to_master_fifo.lpm_numwords = FIFODEPTH; defparam the_user_to_master_fifo.lpm_showahead = "ON"; defparam the_user_to_master_fifo.almost_full_value = (FIFODEPTH - 2); defparam the_user_to_master_fifo.use_eab = (FIFOUSEMEMORY == 1)? "ON" : "OFF"; defparam the_user_to_master_fifo.add_ram_output_register = "OFF"; // makes timing the burst begin single simplier defparam the_user_to_master_fifo.underflow_checking = "OFF"; defparam the_user_to_master_fifo.overflow_checking = "OFF"; endmodule The whole program is from burst_write_master.v in http://www.altera.com/support/examples/download/exm_avalon_mm_master_templates.zip --- Quote Start --- Of course FIFO usedw "has" more than one bit. I guess, you didn't tell the real problem. If you are actually trying to access usedw in Signaltap II or Quartus simulator, you apparently searched the node in the wrong place. It has to be accessed at it's source, in the FIFO compenent directly. --- Quote End --- - Altera_Forum
usedw is not only one bit. If you fifo depth 32 usedw should be 5 bit. And is you will check overfull 6 bit.
