14 years agouse verlog ip in vhdl
I'm trying to use a verilog ip in a vhdl file, first component declaration , then instantiation ... But I keep getting : design library work does not contain ... although I added the file to my proje...
12 years agoHallo!
I want to do the same but i think i've another problem. It seems to me that the i2c_touch_config.v file isn correct. Or I'am not clever enought. There is no effect of the output pins. If i'm touch the screen or not, the oREG_TOUCH_COUNT always shows "11". By the way the value "11" is not possible. The Registers for the touchpositions are set to the maximuml value too. Is there something i havent done ?
