14 years agouse verlog ip in vhdl
I'm trying to use a verilog ip in a vhdl file, first component declaration , then instantiation ... But I keep getting : design library work does not contain ... although I added the file to my proje...
14 years ago --- Quote Start --- And because you have a component declaration, you do not need to use terasictouch : entity work.i2c_touch_config --- Quote End --- Should be better phrased "you must not use". Because the entity work. syntax causes the error.
