14 years agouse verlog ip in vhdl
I'm trying to use a verilog ip in a vhdl file, first component declaration , then instantiation ... But I keep getting : design library work does not contain ... although I added the file to my project ?
What am I doing wrong ?
architecture arch of touchtop_01 is
component i2c_touch_config is
port (
iCLK : out std_logic ;
iRSTN : out std_logic ;
iTRIG : out std_logic ;
oREADY : in std_logic;
oREG_X1 : in std_logic_vector(9 downto 0);
oREG_Y1 : in std_logic_vector(8 downto 0);
oREG_X2 : in std_logic_vector(9 downto 0);
oREG_Y2 : in std_logic_vector(8 downto 0);
oREG_TOUCH_COUNT : in std_logic_vector(1 downto 0);
oREG_GESTURE : in std_logic_vector(7 downto 0);
I2C_SCLK : in std_logic;
I2C_SDAT : inout std_logic
end component ;
begin
terasictouch : entity work.i2c_touch_config
port map (
iCLK => iCLK ,
iRSTN => iRSTN,
iTRIG => iTRIG,
oREADY => oREADY,
oREG_X1 => oREG_X1,
oREG_Y1 => oREG_Y1,
oREG_X2 => oREG_X2,
oREG_Y2 => oREG_Y2,
oREG_TOUCH_COUNT => oREG_TOUCH_COUNT,
oREG_GESTURE => oREG_GESTURE,
I2C_SCLK => I2C_SCLK,
I2C_SDAT => I2C_SDAT
--- Quote Start --- What am I doing wrong ? --- Quote End --- Have you added the i2c_touch_config.v source to the project? And because you have a component declaration, you do not need to use
You can just useterasictouch : entity work.i2c_touch_config
Cheers, Daveterasictouch : i2c_touch_config - Altera_Forum
--- Quote Start --- And because you have a component declaration, you do not need to use terasictouch : entity work.i2c_touch_config --- Quote End --- Should be better phrased "you must not use". Because the entity work. syntax causes the error. - Altera_Forum
Thanks a lot guys !!
Hallo!
I want to do the same but i think i've another problem. It seems to me that the i2c_touch_config.v file isn correct. Or I'am not clever enought. There is no effect of the output pins. If i'm touch the screen or not, the oREG_TOUCH_COUNT always shows "11". By the way the value "11" is not possible. The Registers for the touchpositions are set to the maximuml value too. Is there something i havent done ?
