CPwb0
7 years agoUse factory's image, it restart againand aganin after it work few time
we need update ep4c's fpga and lt's flash epcs64, so I learn an603 use factory image and application image, factory's baseaddr is 0x000000, application base is 0x400000, application can work well, b...
ShafiqY_Intel
7 years agoHI CPwb0,
When you convert your programming to .pof file, try to TICK both of "Disable EPCS/EPCQ ID check" and "Disable AS mode CONF_DONE error check" option.
Go to File > Convert Programming file > Advanced.. > "Disable EPCS/EPCQ ID check" / "Disable AS mode CONF_DONE error check"
I hope this will help.
