16 years agoUse conf.done pin
I am using a Cyclone-IV device which is configured as a combination of a NIOS-II and other logic units. "NIOS II reset" is an input signal to reset the NIOS-II processor inside the FPGA. In ad...
16 years agoHi Jake,
When you take the signal from the optional INIT_DONE line to your external reset generator, you still need a input pin to input your reset signal from your external reset generator to the FPGA in order to reset your NIOS-II and internal logic units. Is that correct? Many thanks, Bcao
