Use an647 design example to send data to PC over Ethernet
I can't find any examples for the Arria V GX board. Do you have a suggestion for which board to look at it?
I went through the Using Triple-Speed Ethernet Tutorial IP for DE2-115 Boards today. I modified it to work with the Arria V GX. I attempted to use the Monitor program but I can't get it to work. I suspect this is because the DE2-115 board has two Ethernet jacks that the NiosII c file uses for the test and the Arria V GX only has a single Ethernet jack.
I am still lost on how to send data from the FPGA to the PC and back. I think I have all the modules I need but I can't figure out how to interact with all the modules to do what I want.
This is the Triple-Speed Ethernet Tutorial I went through.
ftp://ftp.intel.com/pub/fpgaup/pub/Intel_Material/17.0/Tutorials/DE2-115/Using_Triple_Speed_Ethernet.pdf
Also, the simple socket server tutorial seems to send data from the PC to the FPGA. I would like to do the opposite. I'm not sure the simple socket server is what I need here.
