15 years agoUSB Host interface on FPGA
Hello , I want to implement a high speed usb 2.0 host controller on a convenient ALTERA FPGA (Less than or roughly 500$5) for an image processing application. I am aware that I should use an IP...
15 years ago --- Quote Start --- I'm not aware of a suitable low cost development kit involving a HS USB host controller. In so far, it may be necessary to make your own daughtercard, e.g. utilizing NXP SAF1760. SAF is quite flexible with a selectable 1.8 to 3.3 V interface voltage level. The main challenge is still in the software development, I think. --- Quote End --- I googled before about NXP chips but my professor told me that beside this challenge there will be a wiring challenges between the USB controller and the kit especially that this challenge is not my main project . Did anyone here see somebody tried this approach before so I can read about it and know what is the amount of work that will be done ?
