15 years agoUSB Host interface on FPGA
Hello , I want to implement a high speed usb 2.0 host controller on a convenient ALTERA FPGA (Less than or roughly 500$5) for an image processing application. I am aware that I should use an IP...
15 years ago --- Quote Start --- You can find this info by using search box in the top of website with some keywords related before posting questions. --- Quote End --- Do you mean to say there is a solution for the specific requirements of abbfattah (Altera Dev. Kit with HS USB host adapter) or are you just talking about a broad idea of searching the forum for interesting posts? --- Quote Start --- What about FTDI chips, that has USB host? --- Quote End --- F.Y.I. You won't find a HS USB host solution from FTDI.
