12 years agoUSB Blaster problem
Hello, I have a chip USB Blaster Rev C. When I program CPLD EPM7064SLC44-10 with Quartus II sp2 12.0 programmer, the process bar goes to 100% and then it shows "Failed". How can I fix this erro...
12 years ago --- Quote Start --- Hi Yaroslav, What was wrong with the 74LVC125 on the SiLabs USB-Blaster? Your board should have already done that, i.e., the VCC_TARGET pin on the USB-Blaster is supposed to power the buffer inside the USB-Blaster. That is how the USB-Blaster ensures the logic levels transmitted to the board are compatible with the device. If your board did not connect VCC_TARGET, then that would explain the problem. Cheers, Dave --- Quote End --- Nothing ! My CPLD board is designed for ByteBlaster so it has 74HC244 on it to protect the CPLD. I tried to connect USB-Blaster to the same connector, but it did not work. About VCC_TARGET, I didn't know that's why I didn't connect it... Thank you, Yaroslav.
