USB Blaster not recognized in Quartus II 10.0 Web Edition Programmer
High,
i want to start programming FPGA, i use the Terasic DE2-115 eval Board. I installed the USB-Blaster driver which is recognized in the Windows10 Device manager but i can't see it in the programming windows of the Quartus II 10.0 Web Edition.
Have you got an idea why it doesn't appear and how i can solve this issue?
Best regards!
Ettien
- EKPRE
Hi finally,
i solved the issue following theses steps :
1- Install the latest version of quartus Lite 18.1.
2- Download the latest version of DE2-115 CD from terasic website.
3- Change the environment variables to path the quartus installation folder.
4- When running the Control panel, be sure to have the swith on the RUN mode otherwise it doesn't work.
You can find more details on the link bellows :
https://www.coursehero.com/file/27366819/Run-control-panel-under-Quartus-II-150-or-late-versionpdf/
Hope it can help!!!
Best regards.
- Vicky1
Have you resolved the issue?
Shall I consider the case to be closed?
Vicky
- Vicky1
Hi Ettien,
Delete the 'db' & 'incremental_db' folder from your project directory.
Perform 'Full Compilation' in Quartus lite 18.1 & the try to program DE2_115 board.
please let me know if you have any different concern.
Vicky
- EKPRE
Finally I installed the latest Quartus lite version 18.1. It can detect the ubs blaster 2 hardware, but unfortunately I can’t download my FPGA program, it failed.
I also got a lot of error message when running the the DE2_115_control_panel from the DE2-115_v.3.0.6_SystemCD folder.
Best regards !
Ettien
- Vicky1
Update drivers, check the USB blaster cable connection wit the board, check the visual inspection the board especially FPGA pins & refer the link below,
https://www.intel.com/content/www/us/en/programmable/documentation/nfa1418282998564.html
Try to check with Stand alone programmer,
https://www.intel.com/content/www/us/en/programmable/downloads/software/prog-software/100.html
Why don`t you use latest Quartus lite version?
Vicky
- EKPRE
Hi Vicky,
thanks for you answer, i'm downloading the latest version of the quartus lite (18.1) hope it will work.
Best rgards !
Ettien
- sstrell
Are you saying you clicked Hardware Setup in the Programmer and still don't see USB Blaster listed there?
#iwork4intel
- EKPRE
Hi SStrell, yeah the device manager can detect the usb balster but not the Quartus II 10.0 or 12.0. I donwloaded the latest version of the USB blaster 16.0 but it still doesn't work.
