12 years agoUSB-Blaster JTAG max cable length
Hi All, May not have been specific enough with my search, but did not find an answer to my question. I am using the USB-Blaster in JTAG mode. I know that the max cable length on the USB side ...
12 years agoThe acceptable JTAG cable length depends on what you are trying to do with the JTAG. If you are downloading images to the FPGA with a human in attendance then the cost of an error is that you have to do it again - in this case a 99% success rate might be acceptable. If you have an automated system or are debugging a processor then any error will cause problems (JTAG does not have error correction or retransmits)
The chance of getting hit by a bit error also depends on how noisy your environment is - equipment like motors can generate spikes on the JTAG which will cause more problems. If you are not happy with bit errors then I would recommend no more than 5cm of standard ribbon cable, or no more than 20cm of the flexible PCB which comes with the USB-Blaster. You can extend the USB cable quite a lot more (USB has error detection and retransmits). I think you can chain upto 6 powered hubs if you need a longer cable. I would recommend extending the USB side of the connection and keeping the JTAG side as short as possible.
