USB Blaster II Serial Number
Hello.
Is there a serial number for USB-BlasterII that is accessible via the command:
jtagconfig --getparam <cable> <param> ?
We are trying to find a persistent identifier of the cable to be used when simultaneously programming multiple boards using multiple USB-BlasterII cables
For the following command:
quartus_pgm -c "USB-BlasterII [USB-0]" "C:\Firmware\prog.cdf”
We cannot rely on "USB-BlasterII [USB-0]" as cable identifier since it can change when unplugged or which port is detected first when doing reboot/restart. Can we replace that with serial number similar to Xilinx Platform Cable USB II ?
Appreciate any help/clarification on this.
- Farabi_Altera
quartus_pgm -c1 xxxx
quartus_pgm -c2 xxxx
quartus_pgm -c3 xxxx
if you have multiple USB Blaster cable connected to same host.
- WZ2
Hi there,
There is no serial number available, but could you please check if the order changes when you reconnect or reboot the device? For example, if the cable always remains as number 1, you can try:
quartus_pgm -c 1
WZ
- FvM
looking at embedded USB Blaster II hardware on various dev kits, it has no feature to store an unique device ID, e.g. serial number.
Guess the option is neither available on USB Blaster II Programming Cable.
