USB blaster I vs USB blaster II
1) What is main practical difference between those
programmers/debuggers like speed of configuration/debug speeds or
limitations?
USB-Blaster from Altera and Terasic is the same in case of speed as both will be running in 6Mhz while USB-Blaster can run up to 24Mhz. USB-Blaster II will support more features if you planned to use FPGA that support AES. Please refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd01032008_684.html.
2) Why is USB Blaster I more expensive than newer USB
Blaster II?
I don't have this information as you will need to contact the seller for this.
3) Do I understand correctly that Terasic Blaster is clone of
USB Blaster I? I read they share even the same USB ID which Altera
provided to them legally in the past.
Yes.
4) What is compatibility of USB
Blaters in newer Quartus software?
It is compatible.
Hi John,
Thank you very much for answers. It was very helpful. Now, when I know the basics I need to ask additional questions (probably stupid ones) to help me make final decision what will be proper for me.
Because of price I’m deciding between Terasic Blaster and USB Blaster II, where USB Blaster II is more than 4 times more expensive.
Will I get considerably faster:
• Image flashing?
• Signal debugging?
• Soft CPU debugging?
I really want to avoid debugging softcore CPU slowly like with Texas Instrument’s radar chips with real ARM and DSP, where it took each time 3 seconds to make 1 step in C code in theirs modified Eclipse and I’m willing to pay extra to avoid this but only if it’s justified by performance.
I know You wrote Terasic Blater has 4 times slower JTAG clock than USB Blaster but what about USB Blaster II?
Has faster JTAG clock significant real world speed effect for Max 10 family FPGA which is not that “cutting edge”?
I am also interested in securing my design but link You’ve sent me is not mentioning Max 10 FPGA family or any other Max family. Will programming of keys directly into Max 10 devices (or any other security measures) be possible with Terasic Blaster on Max 10 family?
Thank You for Your time.
Petr
