12 years agoUSB Blaster EEPROM Program for Cyclone IV Dev Kit
Hi, I have accidentally erased the EEPROM on my CycloneIV development kit and now the computer sees the USB Blaster as USB Serial interface. I tried to reprogram by using FTDI - FT prog and usb...
11 years ago --- Quote Start --- My EEPROM is blank device. Chip Type: FT232/245BM Vendor ID: 0x0403 Product ID: 0x6001 Product Desc: USB <-> Serial Converter Manufacturer Desc: FTDI Location ID: 0x341 EEPROM Type: 93C46 EEPROM BLANK DEVICE --- Quote End --- You should be able to use FT245B_BLASTR01_xml.txt in the post above. Download the file, change the filename to FT245B_BLASTR01.xml, then in FT_PROG select the FT245 device, right click, apply template, and select the XML file. Then program it. Unplug and plug the device back in, and it should get detected as a USB-Blaster. Let me know if that works. Cheers, Dave
