12 years agoUSB Blaster EEPROM Program for Cyclone IV Dev Kit
Hi, I have accidentally erased the EEPROM on my CycloneIV development kit and now the computer sees the USB Blaster as USB Serial interface. I tried to reprogram by using FTDI - FT prog and usb...
11 years ago --- Quote Start --- I'm using Cyclone IV Transceiver Starter Kit and I got a same problem. I tried FT_Prog with your FT245B configutation but it fails with message "The current drawn from the USB port must be in the range 0 to 500 mAmps." This board uses FT245BL with external EEPROM (AT93C46DN-SH-B). Can you help me? --- Quote End --- Can you first just use FT_PROG to detect devices? What does the EEPROM content look like? Is it blank? I'll check to see if I have a board with an FT245BL on it tomorrow and if I do post the EEPROM contents, if I don't, I can probably make a template that should work. Cheers, Dave
