12 years agoUSB Blaster EEPROM Program for Cyclone IV Dev Kit
Hi, I have accidentally erased the EEPROM on my CycloneIV development kit and now the computer sees the USB Blaster as USB Serial interface. I tried to reprogram by using FTDI - FT prog and usb...
12 years agoHi Emre,
--- Quote Start --- I use version 2.8.2.0 of FT Prog and the device manager says it is a USB <-> Serial interface. If you can post the appropriate XML file it will be great. If that doesnt work than I guess sometihng happened to EEPROM. --- Quote End --- That is not quite enough information for me to post the correct XML. What type of device does FT_PROG indicate is on your board? Actually, I'll just post configurations for both the FT245R and FT245B ... I'll fire up my laptop and check that it has the same version of FT_PROG and then upload the images ... back shortly. Cheers, Dave
