18 years agoUSB Blaster driver conflict with other FTDI kit
Hi, I am using a USB blaster (Terasic) and on the same system I need to use two Asix Presto programmers that use the same FTDI device and (apparently) drivers. The Presto devices load up and...
9 years agoI just upgraded to Quartus 16.1 and now I have this problem.
Without the FTDI cable plugged in USB-Blaster is at port USB-0, and I can program my device through JTAG. With the FTDI cable plugged in the USB-Blaster changes to USB-1, and I can still program my device through JTAG. With the FTDI cable plugged in as USB-1 and PuTTY open, then I cannot program my device through JTAG - the Quartus programmer reports "No Hardware". Closing the PuTTY window allows the programmer to work again.
