18 years agoUSB Blaster driver conflict with other FTDI kit
Hi, I am using a USB blaster (Terasic) and on the same system I need to use two Asix Presto programmers that use the same FTDI device and (apparently) drivers. The Presto devices load up and...
18 years agofor windows xp there is a quite simple solution (I don't know for vista).
- In the quartus/drivers/usb-blaster/x32 (or x64) directory, rename the ftdibus.sys to something else (ftdibus1.sys), change all references to ftdibus.sys in the usbblst.inf file to the new file name. - uninstall the driver (device manager...) - uninstall all usb-serial adaptors ( although I don't know is this is ncry) - plug out the usb blaster - plug in the usb blaster - reinstall the driver - reinstall the serial port adaptors Good luck Stefaan
