USB Blaster disapears from the hardware setup of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter.
Have you tried to change the Hardware setup via the Quartus Programmer. In the Programmmer, click the Hardware Setup button, then in the drop down box, try and select the USB Blaster hardware if it is listed there.
Of course I tried, there is no usb hw present in the list when my terminal is open with the com port (that was my original issue).
I tested with quartus 18.1, same issue.
To work around the problem, I will program my FPGA using another pc.
- ShafiqY_Intel7 years ago
I'm apologize for misunderstanding.
- AEsqu7 years ago
Contributor
Your statement is incorrect.
Please read the original question before reacting.
If it works using another PC, mean your Quartus/previous PC got problem.
Have you try to re-install your Quartus?
- AEsqu7 years ago
Contributor
Am I talking to a robot?
If this is a workaround, that means that it works ...
But that is just a workaround.
Hi AEsqu,
Let us know the results when you program it using another pc. Thanks
