AEsqu
Contributor
7 years agoUSB Blaster disapears from the hardware setup of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter.
USB Blaster disapears from the hardware setup (no hardware) of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter. The only way to see the usb ...
AEsqu
Contributor
7 years agoI use this path with an official Altera USB Blaster (same behavior with a Terasic USB blaster):
C:\intelFPGA_pro\17.1\qprogrammer\drivers\usb-blaster
So I use the programmer 17.1
