AEsqu
Contributor
7 years agoUSB Blaster disapears from the hardware setup of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter.
USB Blaster disapears from the hardware setup (no hardware) of the quartus prime programmer when I connect a com port with the teraterm using an FTDI usb to I2C adapter. The only way to see the usb ...
ShafiqY_Intel
7 years agoHi,
You can try this solution. You may need to select the correct path when installing the usb blaster, the path should be
<Path to Quartus installation>\drivers\usb-blaster \
not
<Path to Quartus installation>\drivers\usb-blaster\x32\
<Path to Quartus installation>\drivers\usb-blaster\x64\
In addition, which Quartus version and Intel FPGA device you are using?
Thanks 😉
