cosx
7 years agoUSB blaster connection from DE0 board to windows10
Hi everyone, I came across a very tricky problem. My DE0 board could not connect to windows 10 due to missing drivers. After manually using quartus ii 13.1 usb driver *64 sub folders, still c...
Vicky1
7 years agoHi,
Can you confirm it manually that usb-blaster directory is present in Quartus13.1 installed directory.
Refer the instructions as mentioned in below,
http://www.terasic.com.tw/wiki/Altera_USB_Blaster_Driver_Installation_Instructions
Could you please check with installing standalone programmer using below,
you can also check by reinstalling the Quartus 13.1 setup.
Vicky
- cosx7 years ago
Hi there,
thank you for your help!
Here is the result of my driver situations:
This always happens, even if I download the stand alone software as you suggested.
Probably I need to redownload my software.
Thanks anyway!
Mingqiang
