URGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
What Quartus version do you work with? The NIOS EDS is a download at the Altera website, right next to Quartus.
From the IDE help, I guess it should be right-click on the project, then select properties, System library properties. - Altera_Forum
huh? where to get SBT?
You should consider switching to the SBT (software build tools) flow. It has been the default for a number of Altera software releases now....soon the "classic/IDE" flow will go away.
Cheers, slacker - Altera_Forum
I dont see the BSP project. I am using Nios II IDE.
IIRC: Right-click on the BSP project, ->Nios II->Edit BSP settings
Under drivers, all periphereals should be listed. - Altera_Forum
how to disable it? I cant find it. where is the BSP setting?
Dont forget to disable the DMA drivers in the BSP settings, or it won't work.
The HAL DMA init does something weird to the DMA... - Altera_Forum
--- Quote Start --- my code does both, with double DMA and interrupts. But I don't have it here, because i'm already in the weekend ;-))) --- Quote End --- ok. thanks! i will try the dma register now - Altera_Forum
But I don't have it here, because i'm already in the weekend ;-))) - Altera_Forum
--- Quote Start --- Yes, I had the DMA drivers work in one direction, but not the other. Whatever I tried, no luck. Look in the Quartus Handbook DMA chapter (google for altera nios dma). The registers are explained there. You have a status register, read and write address, length and some control bits. you program them like you did with your periereal: IOWR(AVALON_0_BASE,reg,val); Adresses and length should be obvious. You only need to select the correct control bits. --- Quote End --- Ok. thanks! I will try it now. I am trying to transfer from peripheral to sdram. if this works, then i think it should be enough. your code is transferring from peripheral to mem or mem to peripheral?
