15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years agoYeah, i did edit the signal... the result still the same... does it consider as correct for the result?
hahaha. i dont know how to connect the signal to interrupt, so i just use tristate buffer. in the attachment, the picture (block.jpg) is the overall block. now i have the block, how to connect that block with DMA?
