15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years agoI have done with the connection. But the result i got is weird. i am not sure what is the problem. could you pls help me to check? pls see the attachment. thanks!
Notes: When address is '0', the adder will write the data (writedata) to be calculated, and when '1', adder will send calculated data (readdata) to result.
