15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years agoDMA is Avalon-MM (memory map) and SGDMA is Avalon-ST (streaming memory)
memory-to-memory (onchip to sdram, sram to sdram) stream-to-memory (buffer array to sdram, buffer to sram) memory-to-stream (sdram to buffer array, sram to buffer). You should read more about Avalon Interface Spec. Sean
