URGENT NEED OF INFORMATION - CRE_ITEMMASTER_20221215
Below I will provide the answer.
LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ? : Active
IF NRND, PLEASE PROVIDE LTB AND LTS DATE : -
IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT : -
IS THIS PART AVAILABLE IN TAPE&REEL PACKAGING (YES/NO).? : TRAY
IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER : -
DESCRIPTION MATCHES WITH MPN (YES/NO) ? : YES
GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT/ INVALID ? : Correct
IF NO SUGGEST CORRECT ORDERABLE MPN : -
MOISTURE SENSITIVITY LEVEL (MSL) ? : 3
ROHS COMPLIANT WITHOUT ANY EXEMPTION (YES/NO) : YES
IF NO THEN WHAT IS THE EXACT EXEMPTION ? : -
PACKAGE/CASE SIZE : Height(2.63), WIdth(29), Length(29)
MOUNTING TYPE: (SURFACE MOUNTED/THROUGH HOLE) : SURFACE MOUNTED
PART MARKING : -
DATASHEET/DRAWING SHEET : https://static6.arrow.com/aropdfconversion/c62f523124b7f65ca7f23d677d9564cfbf400345/attachment.pdf
Nazrul Naim
