[URGENT HELP] Add addition single Counter BIT HELP!
---------- Code Removed ----------
Yes, as said by setting up a two digit BCD counter, using two decimal (modulus 10) counters. Each decimal counter drives one digit. That has been basically correct in your schematic, just the overflow respectively carry wasn't.
Hmm, FvM,
let say if i using Digit1,Digit2 : in std_logic_vector (3 downto 0); process(digit1,digit2) is there any way to count 0 - 99 for digit1 and digit2 for output - Altera_Forum
As far as I remember, LPM_COUNTER doesn't offer a BCD counter option. So you would use to modulus 10 counters, carryout of the lower digit connected to carry in of the higher digit, clk parallel to both. Of course, you can implement the carry in and out also in a VHDL counter of your own.
Hey FVM,
Ok, I understand, The block diagram is work as ripple carry counter. That caused i can't capture the value of double digits. I now have 2 separate 7 segment display. If i'm using single LPM_Counter to do the counter, also able to project 2 separate 7 segment display together? - Altera_Forum
Without the schematic top entity, the intention of the design actually can't be understood.
In my understanding, you have two, loosely related objectives: - Design a two-digit BCD counter - make it switch a led on count 31 You have tried to solve it by separate counters, and curiously placed an additional binary counter into a BCD digit counter. That's really arbitrary, but not impossible of course. I don't want to support this crude coding style however and would suggest to connect the compare to the BCD counter output, so you have only one counter. The BCD counter upper digit is wired incorrectly. You are operating it as a ripple carry counter, if so, the upper digit must be clocked on the falling edge. But a ripple carry counter is bad coding style anyway. To make it a synchronous counter, you have to add carry in- and outputs. You can consult the LPM_COUNTER MegaFunction as a reference. - Altera_Forum
Is it possible that your signal clk remains high or low ?
Measure on the clk plz. (Hang an output on it) Its confusing if u use clk for an input pin cauze clk refers to clock. - Altera_Forum
I tested out on circuit board. hmm, if there any way i can add a if statement on the pushbutton(clk) once i pressed 1 time, i able to automatic count_counter<=count_counter+1??
If - Altera_Forum
Can i see the result of your testbench ?
---- code removed ---
I don't understand your meanings.
U are already using the component BCD_counter 2 times. 1 time to count from 0 to 9 (0 , 1 , 2 , 3 , ...) 1 time to count from 0 to 90 (0 , 10 , 20 ,30 , ...) Does that works ? If so -> than look for LED = 31 to blink.
