15 years ago[URGENT HELP] Add addition single Counter BIT HELP!
---------- Code Removed ----------
15 years agoHey FVM,
Ok, I understand, The block diagram is work as ripple carry counter. That caused i can't capture the value of double digits. I now have 2 separate 7 segment display. If i'm using single LPM_Counter to do the counter, also able to project 2 separate 7 segment display together?
