16 years agoUrgent! hardware interface between FPGA DE2 board(3.3V) and ADC(5V)
HI, may i ask your guys a favor. I am using DE2 board for my project and i need to interchange signals(SPI) to an ADC. The ADC is 5V for logic high but the max output signal for DE2 board is only ...
16 years agoHi, thanks again for your reply.
While waiting to the HCT, i tried another translator, it work but no up to 1MHz, it is only up to 2ooKHz for the squrewave without turning into sawtooth wave. The HCT f my order haven't reach me yethttp://www.alteraforum.com/images/smilies/mad.gif http://rapidshare.com/files/371907323/sn7407.pdf.html May you refer to the the pdf above, page 4 the 1st circuit connection? I constructed according to this but i didn't put the capacitor as i don't need a filter.Thus, i only use the pull up resistor. The Vcc is 5V. Then there is no problem after output of translator is fine. Problem occurred when i connected to ADC( i supply 2 control signals).The waveform distorted when i combine this translator and ADC. Please refer to : http://rapidshare.com/files/371894736/upload.rar.html I doubt if it is the internal structure of ADC that makes the waveform distorted when 2 signals are transferred. No distortion if only 1 connection is made between ADC and translator but there will be if more than 1 lines are connected. One more thing, can you let me know about the Vih?
