16 years agoUrgent! hardware interface between FPGA DE2 board(3.3V) and ADC(5V)
HI, may i ask your guys a favor. I am using DE2 board for my project and i need to interchange signals(SPI) to an ADC. The ADC is 5V for logic high but the max output signal for DE2 board is only ...
16 years ago --- Quote Start --- 74LVC is a "3.3V node" logic, so it's not suited for 3.3V to 5V translation, but it's good for the 5V to 3.3V direction, as I previously stated. It surely works for the 8 MHz speed required with ADS7861 (and a lot more). I verified, that ADS7861 has a 5V CMOS level specification (VIH > 3.5V) so it can't be reliably driven by DE2 3.3V logic outputs. A 5V logic IC with TTL level specification (VIH > 2.0 V) can perform the conversion. 74HCT244 would be suitable 3.3 to 5V translator (or 74HCT04 for inverted signals). --- Quote End --- Good morning,Fvm. I still facing problem in voltage level conversion. When i separated ADC and DE2 board. The output of voltage translator can be converted from 3.3V to 5V. However, after i combine the input of ADC(clk and conversion start control signal) to the output of voltage translator, the signal is distorted and it cant reached 5V(De2(3.3V) --> input (3.3V)voltage translator output (5V--- measure here after combine with ADC) --> ADC). This even worse for my conversion start signal. There is nothing extra along the transmission of signal between this two ports expect a pull up resistor connector at the output of translator(i connect according to datasheet, the conversion of 3.3V to 5V would not work if i remove this resistor ). I just wondered that u stated ADS7861 has a 5V CMOS level specification (VIH > 3.5V). I have no idea what is the problem. Is it because of the internal voltage of ADC ?(it has some when i measure the output of ADC when it connect nothing). One more thing is about the Vih. Of course when i refer to my lecturer, he told me the Vih is high than 3.3V and i need to use a translator. However, the Vih is only 3V to Vdd+0.3 when i refer to page 3 of datasheet. You mention before it is a 5V CMOS and Vih is more than 3.3V, may i know where you verify that?
