15 years agoUpdating Look-Up Table with .mif or .hex file
Hi, I am implementing a Look-up Table that would require being updated from either a .mif or .hex file generated from MATLAB. I am thinking of using a two-port RAM block, where one port could...
15 years agowhen you run the process in the GUI it will show the command in the Messages window. you can put that into a script
