15 years ago
Updating Look-Up Table with .mif or .hex file
I am implementing a Look-up Table that would require being updated from either a .mif or .hex file generated from MATLAB. I am thinking of using a two-port RAM block, where one port could be used to update the LUT entirely and the other port for normal operations.
My concerns are as follows:
- is it possible to update the LUT by feeding an updated .mif file (is there any way of getting the RAM to re-read the .mif file for new values) without re-compiling the design?
- is there an option to implement a LUT with two columns, where the input to the LUT would search for itself (the input value) in column 1 and output the corresponding value from column 2?
Your help and guidance will be highly appreciated :).
    When you create a supported ram in megawizard, quartus gives you the option of using that tool (in system mem editor) so tick the box. Then after compilation and download open the editor from tool's menu and navigate to your mif/hex file... The tool updates ram via jtag. very simple.
    Kaz, could you please give details on "using in system memory editor to update the data"?
    Thank you.
    You also can use in system memory editor to update your data
    when you run the process in the GUI it will show the command in the Messages window. you can put that into a script
    Thank you very much for this.
    But this is something you do manually at your convenience right. Is there a way to automate the updating process at regular intervals?
