Updating FIM and BMC for Arria 10 PAC
Hi, I am running on Ubuntu 18.04, kernel 4.15.0-201-generic, and I need to update the firmware for an Arria 10 PAC to the latest version.
I cannot load any GBS on the board, e.g.,:
$ sudo fpgaconf /inteldevstack/a10_gx_pac_ias_1_2_1_pv/hw/samples/hello_afu/bin/hello_afu_unsigned.gbs -vvvv Reading bitstream Looking for slot No suitable slots found. Expected Interface id: d4a76277-07da-528d-b623-8b9301feaffe Actual Interface id: 38d782e3-b612-5343-b934-2433e348ac4c
This is the current output of fpgainfo:
$ sudo fpgainfo fme Board Management Controller, microcontroller FW version unavailable Last Power Down Cause: unavailable Last Reset Cause: unavailable (can't open) //****** FME ******// Object Id : 0xEF00000 PCIe s:b:d:f : 0000:01:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x123456789ABCDEF Bitstream Version : 1.2.3 Pr Interface Id : d4a76277-07da-528d-b623-8b9301feaffe Boot Page : user
From https://www.intel.com/content/www/us/en/docs/programmable/683415/1-0-production/1-0-reference-table.html , I can make out that a flash failover occurs and the factory image is loaded.
I installed the Acceleration Stack v1.2.1 with both updates from https://www.intel.com/content/www/us/en/software-kit/665840/intel-pac-with-intel-arria-10-gx-fpga-acceleration-stack-version-1-2-1.html . This are the resulting installed modules:
$ lsmod | grep fpga intel_fpga_pac_iopll 16384 0 intel_fpga_pac_hssi 24576 0 intel_fpga_fme 94208 0 intel_fpga_afu 36864 0 intel_fpga_pci 28672 2 intel_fpga_fme,intel_fpga_afu fpga_mgr_mod 16384 1 intel_fpga_fme ifpga_sec_mgr 16384 2 intel_fpga_fme,intel_max10
I tried to perform an OTSU update, as suggested in https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/updating-fpga-flash-and-bmc-firmware.html . It seems that some drivers are either missing or corrupt:
$ sudo fpgaotsu --log-level=debug /usr/share/opae/a10-gx-pac/fpgaotsu/base/otsu-09C4.json [2023-01-13 19:46:12,823] [DEBUG ] [MainThread] found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2023-01-13 19:46:12,823] [DEBUG ] [MainThread] found device at 0000:01:00.0 -tree is [pci_address(0000:00:01.0), pci_id(0x8086, 0x1901)] [pci_address(0000:01:00.0), pci_id(0x8086, 0x09c4)] [2023-01-13 19:46:12,823] [DEBUG ] [MainThread] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi*/spi_master/spi*/spi*" [2023-01-13 19:46:12,824] [DEBUG ] [MainThread] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/ifpga_sec*" [2023-01-13 19:46:12,824] [INFO ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0 is not secure. [2023-01-13 19:46:12,824] [DEBUG ] [MainThread] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/avmmi-bmc.*.auto" [2023-01-13 19:46:12,824] [WARNING ] [MainThread] "requires" expression bmc_aux_fw_rev >= 26889 failed [2023-01-13 19:46:12,824] [WARNING ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0 one or more prerequisite checks failed. Skipping this device. [2023-01-13 19:46:12,824] [WARNING ] [MainThread] Update starting. Please do not interrupt. [2023-01-13 19:46:12,824] [INFO ] [MainThread] Total time: 0:00:00.000003 [2023-01-13 19:46:12,824] [ERROR ] [MainThread] One-Time Secure Update failed
I also tried a SUPER-RSU update, getting similar errors:
$ sudo super-rsu --log-level=debug /usr/share/opae/a10-gx-pac/super-rsu/base/rsu-09c4.json [2023-01-13 19:52:57,877] [DEBUG ] [MainThread ] - found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2023-01-13 19:52:57,878] [DEBUG ] [MainThread ] - found device at 0000:01:00.0 -tree is [pci_address(0000:00:01.0), pci_id(0x8086, 0x1901)] [pci_address(0000:01:00.0), pci_id(0x8086, 0x09c4)] [2023-01-13 19:52:57,878] [DEBUG ] [MainThread ] - could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/ifpga_sec*" [2023-01-13 19:52:57,878] [WARNING ] [MainThread ] - [0000:01:00.0] does not support secure update [2023-01-13 19:52:57,878] [ERROR ] [MainThread ] - missing one or more items required by rsu config [2023-01-13 19:52:57,878] [INFO ] [MainThread ] - super-rsu exiting with code '78'
The same errors happen if I manually try to update a specific piece of firmware, .e.g.,:
$ sudo fpgasupdate /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4-26895-fw_Release.bin --log-level=state [2023-01-13 20:29:58,766] [DEBUG ] fw file: a10sa4-26895-fw_Release.bin [2023-01-13 20:29:58,766] [DEBUG ] addr: ssss:bb:dd.f [2023-01-13 20:29:58,767] [DEBUG ] hash256: d2ec8a2dc11299da8e4eace776596ba52a685d44e81987f1abb85c846079af6b [2023-01-13 20:29:58,767] [DEBUG ] hash384: ec235c4a07ce7a0a2b43bfe9f2fcf2fc18d4a5410abf0fba31bdff5f9e47285d75bd45658ade878988fc736997827045 [2023-01-13 20:29:58,767] [DEBUG ] file type: BMC Image (Update) [2023-01-13 20:29:58,767] [DEBUG ] found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2023-01-13 20:29:58,767] [DEBUG ] found device at 0000:01:00.0 -tree is [pci_address(0000:00:01.0), pci_id(0x8086, 0x1901)] [pci_address(0000:01:00.0), pci_id(0x8086, 0x09c4)] [2023-01-13 20:29:58,767] [WARNING ] Update starting. Please do not interrupt. [2023-01-13 20:29:58,768] [DEBUG ] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi*/spi_master/spi*/spi*" [2023-01-13 20:29:58,768] [DEBUG ] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/ifpga_sec*" [2023-01-13 20:29:58,768] [ERROR ] Failed to find secure device for PAC 0000:01:00.0
I downgraded the Acceleration Stack to v1.1 and tried to flash the stock bitstream, getting a timeout error:
~/intelrtestack/a10_gx_pac_ias_1_1_pv/hw/blue_bits$ sudo fpgaflash user dcp_1_1.rpd 2023-01-13 20:04:23.053942 reversing bits 2023-01-13 20:04:33.040600 erasing 0x04000000 bytes starting at 0x04000000 Traceback (most recent call last): File "/usr/bin/fpgaflash", line 11, in <module> load_entry_point('opae.admin==1.0.2', 'console_scripts', 'fpgaflash')() File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaflash.py", line 1283, in main ret = rc_fpga_update(args.file, args.type, bdf, args.no_verify) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaflash.py", line 872, in rc_fpga_update no_verify) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaflash.py", line 416, in fpga_update no_verify) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaflash.py", line 368, in update_flash flash_erase(mtd_dev, target_offset, erase_len) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaflash.py", line 156, in flash_erase fcntl.ioctl(file_.fileno(), MEMERASE, ioctl_data) IOError: [Errno 110] Connection timed out
I also tried to downgrade the Acceleration Stack to v1.0, for both RTE and DEV environments, but they do not support Ubuntu and the installation hangs.
W.r.t. v1.2, the download links, available at https://www.intel.com/content/www/us/en/software-kit/665840/intel-pac-with-intel-arria-10-gx-fpga-acceleration-stack-version-1-2-1.html , do not work.
Furthermore, I do not have JTAG access to the board.
Is it possible to install the latest firmware version from my situation?
Thanks for the help,
Vincenzo.
Bitstream with 1.2.1 version will have AES which you will not be able to directly update it. Older version will work without any issue as it wil not have the security feature enable.
- vincenzo_m
Does this mean v1.2 could be programmed directly via the USB Blaster II?
This way I could update directly to v1.2.1 using the instructions in the User Guide, i.e., with fpgaotsu and super-rsu, without passing through all the old versions.
- JohnT_Altera
It is possible.
- vincenzo_m
Great.
Thank you very much for the support.
- JohnT_Altera
May I know if you have any other queries?
- JohnT_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
