vincenzo_m
3 years agoUpdating FIM and BMC for Arria 10 PAC
Hi, I am running on Ubuntu 18.04, kernel 4.15.0-201-generic, and I need to update the firmware for an Arria 10 PAC to the latest version.
I cannot load any GBS on the board, e.g.,:
$ sudo fpgac...
- 3 years ago
Bitstream with 1.2.1 version will have AES which you will not be able to directly update it. Older version will work without any issue as it wil not have the security feature enable.
JohnT_Altera
3 years agoHi,
Since the bitstream is currently incorrect then the only way is to use USB Blaster to prograrm the FPGA. May I know if you have the blaster to program the FPGA?
