vincenzo_m
3 years agoUpdating FIM and BMC for Arria 10 PAC
Hi, I am running on Ubuntu 18.04, kernel 4.15.0-201-generic, and I need to update the firmware for an Arria 10 PAC to the latest version.
I cannot load any GBS on the board, e.g.,:
$ sudo fpgac...
- 3 years ago
Bitstream with 1.2.1 version will have AES which you will not be able to directly update it. Older version will work without any issue as it wil not have the security feature enable.
vincenzo_m
3 years agoThe board from 05:00.0 is the board that was previously plugged in the 01:00.0 slot.
This was is original "fpgainfo" before I attempted any update:
$ sudo fpgainfo fme Board Management Controller, microcontroller FW version unavailable Last Power Down Cause: unavailable Last Reset Cause: unavailable (can't open) //****** FME ******// Object Id : 0xEF00000 PCIe s:b:d:f : 0000:01:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x123456789ABCDEF Bitstream Version : 1.2.3 Pr Interface Id : d4a76277-07da-528d-b623-8b9301feaffe Boot Page : user
After trying some updates with fpgaotsu and super-rsu, with versions v1.1 and v1.2, the signatures changed:
Furthermore, the output of "fpgainfo fme" now shows a different Pr Interface Id, which I can't find reference of in any user guide or anywhere the internet.
