GD76's avatar
GD76
5 years ago
Update MAX10 CFM from Microcontroller using serial interface.
After reading the Max10 user config document and looked at I2C RSU, not sure of this. The FPGA cannot have NIOS. The I2C based user logic described in User config need NIOS. My legacy boards has a microcontroller running C firmware and a FPGA. However, the JTAG of the FPGA are not accessible for field upgrade directly. A serial SPI is available that connects the FPGA to the microcontroller. In legacy, the old FPGA bitstream (RBF file) is packaged together with firmware and programmed onto an external flash. The microcontroller through SPI updates the SRAM based FPGA. The FPGA is obsolete. Looking to upgrade that to Max10 FPGA. Looking for full app note and reference design that can walk me through using Max10. The microcontroller may update the FPGA's CRAM or the CFM. It is confusing reading through the dual configuration because it does not look similar to what I want to do.
