14 years agoUnused CPLD Pins
I have two CPLDs on my PCB that connect to a common SPI bus. In order to keep things simple I'm trying to talk to only one of the chips at first but I'm having some trouble with the voltages which le...
14 years agoIndeed! If I change the device to a Cyclone the default is the same one. If I change it to Max V, it's set to "as outputs driving ground".
