14 years agoUnused CPLD Pins
I have two CPLDs on my PCB that connect to a common SPI bus. In order to keep things simple I'm trying to talk to only one of the chips at first but I'm having some trouble with the voltages which le...
14 years ago --- Quote Start --- Oh, I'm so sorry. Long day at work! Yes, there's no 22 Ohm resistor. The schematic is slightly out-dated. I AM using 22 Ohm resistors in place of 100. Considering that, do you think it's bus contention? --- Quote End --- Now you will understand the beauty of having a resistor in your signal path ... remove it, and toggle the source signal, it should be 3.3V logic levels. Probe the destination signal, what voltage is it? Wire things back together, using a larger resistor to protect your circuit, and continue debugging. Look at the package diagram for the CPLD. Is your bad signal on a pin next to a power rail? Perhaps you have a short between the destination signal and a power pin next to it. Keep in mind that debugging is the fun part, its where you really learn how things work. Cheers, Dave
