emrahener
3 years agoUnused Agilex F Tiles and recovered clk output.
We are using AGIB027R31B2E2V on our digital board design. We are using FHT13C but not using FHT13A. Pin Connection guideline says Tie to GND if there is no FHT channel used for the followi...
AqidAyman_Altera
3 years agoHi,
You can treat each tile on the device as a totally independent from each other. So, any unused XCVR tile can be connected to GND. In your case is FHT13A. As for I_PIN_PERST_N_GXF, it just depends on the usage of PCIe, it should not impact the ethernet links.
Aqid
