9 years agoUnrecognizable characters received via NIOS II UART
Hi all, I am configuring my DE0-Nano SOC kit for NIOS based UART communication (RS232). Everything is done as per the available literature. Connections are also done as: GPIO[1] as Rx connect...
9 years ago --- Quote Start --- ~30mV peak-to-peak. Do you think this might be the issue in the decoding of erroneous data? Can you please suggest something else?Thanks --- Quote End --- This was because my DSO probe was faulty. Now, I am able to receive the intended data after I replaced an old level translator IC (Max232 chip). So, this thread is [CLOSED] from my side. Thanks.
