Joakim
7 years agoUnnecessary long routing path creates timing issues
I'm using the same component in two different designs. On one of them it passes the timing the timing requirements, but not on the other. If I look in the details I can see that the failing design ...
Joakim
7 years agoI decided to go for using Logic Lock, just curious on why the tool can't find a better routing on it's own.
