9 years agoUninitialized value of a signal in vhdl
This may be a noob vhdl question, but I have stuck at this point! Consider the following codes (a test bench which uses a detector and write entities). Since the reset signal (r) is set to 1, I expect that we signal goes to 0 but the simulation shows that the value of we is u which means uninitialized. You may try this code!
testbenchentity test_tb is
end;
architecture x of test_tb is
component test_detector port( clk: in std_logic;
rst: in std_logic;
count: in integer range 0 to 7;
z: out integer range 0 to 7;
we: out std_logic );
end component;
component test_write port( a: in integer range 0 to 7;
oe: in std_logic;
clk: in std_logic;
z: out integer range 0 to 7);
end component;
signal clk: std_logic := '0'; -- clock
signal r: std_logic := '1'; -------------------------------------- reset is initialized to '1'
signal count: integer range 0 to 7 := 2;
signal z, num: integer range 0 to 7;
signal we: std_logic;
begin
u2: test_detector port map( clk, r, count, z, we );
u3: test_write port map( z, count, we, clk, num );
process( clk )
begin
clk <= not clk after 2 ns;
end process;
process
begin
r <= '1'; ---------------------------- reset is '1'
wait for 4 ns;
r <= '0';
wait;
end process;
end; detector entity test_detector is
rst: in std_logic;
end;
architecture my1 of test_detector is
begin
process( rst )
begin
if rst = '1' then ----------- this condition is true
we <= '0'; ------- we should be 0
end if;
end process;
process( clk )
begin
if (clk'event and clk = '1') then
if count = 1 then
z <= 7;
we <= '1';
end if;
end if;
end process;
end;
write entity test_write is
oe: in std_logic;
clk: in std_logic;
end;
architecture behav of test_write is
begin
process( clk )
begin
if (clk'event and clk = '1' and oe = '1') then
if (count < 7) then
z <= a;
end if;
end if;
end process;
end; Can someone explain what is going on?1 Reply
First of all - I would do two things and retest:
1. Have we assigned in only a single process - otherwise you'll get multiple driver problems 2. remove the initial value of r. You're setting it at time 0 anyway.
